Viore PD50VH80 50" Plasma`
  • kevinm34232
    • May 2012
    • 1884
    Re: Viore PD50VH80 50" Plasma`
    Regarding the transistors in post #6, is this a problem?
      Originally posted by kevinm34232
      Should I have 120VAC on both sides of this component?
      Yes, I think so.
      • kevinm34232
        • May 2012
        • 1884
        OK trying to trace this to the best of my ability..
        Tom is the spot with the ? where the 2nd relay would give the bridge the HOT side 120VAC?
        I have the 120VAC at the 2 spots noted, where it hits those 2 diodes. Is this where it's going to the standby section?
        So is the AC sectioin fine then?
          I don't have a schematic of the exact same board but I have one from a different model, same generation. You should be able to understand how the input circuit works -- more or less the same.
          • kevinm34232
            • May 2012
            • 1884
            Thanks for that..
            What is the TH relay for? Neither one is clicking on, but I do have 120VAC across pins 1 and 2 of RL802S, but not RL801S.
            Which relay circuit do I need to focus on?
              The TH relay bypasses the NTC once the power supply has started, this improves efficiency. The TV can work if this relay does not energise but it can lead to picture issues and overheated NTCs.
              The ON/OFF relay turns the main power on to the PFC circuit which boosts the supply to 400V. The standby should still work without this relay functioning.
              Note the 22uF/450V should have 160V in standby (US) and around 390V in operation, as it gets an extra feed in from the PFC circuit. If you don't have anything (160V) at that capacitor, then there's a fault on the input circuit somewhere or a blown fuse that's not obvious somehow.
              Power on sequence (after power button pressed):
              - ON/OFF relay toggled
              - ~100ms delay
              - TH relay triggered
              - PS ON signal activated
              • kevinm34232
                • May 2012
                • 1884
                I traced back from the + of the 22uF/450V cap and it only goes thru the fuse next to it, then thru 2 diodes (DB810 and DB811) back to the pins where I have 120VAC at the NTC. Diodes seem to be fine and there is 120VAC at the anode of DB810
                But I only have about 1VDC across that cap.
                  The diodes are not open? No cold joints? Try measuring the voltage drop across the diodes that feed that cap.
                  • kevinm34232
                    • May 2012
                    • 1884
                    Does it matter which probe to where, or just either way across the dioide? DC or AC? Also, can I measure the V out of each diode and what would I use for ground?
                      What meter do you have -- is it True RMS capable? If so, AC or DC range across them will work.
                      • kevinm34232
                        • May 2012
                        • 1884
                        It's a cheapie meter. Set on AC I get a reading of around 7V across the first diode, about 0.5V across the second one.
                          Can you highlight that diode on the board somewhere?
                          • kevinm34232
                            • May 2012
                            • 1884
                            Here's from the bottom I will get from the top now, which diode are you looking at?
                            • kevinm34232
                              • May 2012
                              • 1884
                              From top../
                                Well, it's just a 1N4007. You could try replacing it (radioshack sell them) along with the others near it -- just leave the diode DB801 near the transformer alone.
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  You're talking about the one next to the cap? What should I expect to see as the 120VAC goes into the first diode into the 2nd one, it should be coming out at 160VDC?
                                    You should have 160V across the cap, but the layout of the diodes is really unclear I'm not sure what they each do. I wish I could get the exact schematic.
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      I have a UF4007GP-TP will that work for the 1N4007?
                                        That will be fine it is the ultra fast variant of the 1N4007 and would in fact be suitable for DB801 too, though I don't think you need to replace that.
                                        If you give up, the board is about $50.
                                        http://www.shopjimmy.com/samsung-lj4...upply-unit.htm
                                        • kevinm34232
                                          • May 2012
                                          • 1884
                                          Ya I got a offer in on one on ebay now for $30. I hate to give up on it tho, Im gonna try replacing that diode, perhaps lifting the diode next to it that also goes to the fuse and then goes somewhere else.
                                          Nah didn't work.. There is a 6 pin ICB801S (ICE3BR2565JF) close to this cap
                                          http://www.alldatasheet.com/datashee...3BR2565JF.html
                                          Could you look at this I think it produces the standby?
                                          Checking the from the cap ground, it showing a short to pin 2 (current sense). Is that normal?
                                          Edit: There is 0VDC to the VCC pin, that pin leads to a pin on the TB801S transformer.
                                          I will try to search for a schematic
                                          • KYBOSH
                                            VIORE PDP4210EA Plasma TV 42 inch - No Video on DVI
                                            by KYBOSH
                                            Got my hands on an relatively unknown TV brand about two weeks ago.
                                            I certainly hadn't heard of it before.
                                            Previous owner didn't give a description of what was wrong and when I got it the back cover was already off.
                                            I put it on the back burner until I had so spare time to look it over.
                                            Today was that day.
                                            I plugged it in and was surprised to see that it started up without any issues.
                                            This is an older TV and the most modern video input that it has is DVI.
                                            I was scrambling to find a DVI connector or adapter as I haven't fooled with that...
                                            01-27-2023, 08:19 PM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            10-08-2025, 07:34 AM
